Performance Short Shift Gear Lever Kit
Re: Performance Short Shift Gear Lever Kit
Post by marco_polo » Fri Aug 31, 2012 8:59 pm
Yup. Or a specialist like BmMiniParts.
Tanda129
Post by Tanda129 » Wed Apr 03, 2013 2:20 pm
hi guys
im new to the forum but have analysed your mods quite alot. i have bmw e90 320d and dont have anyone on e90 forums who has done this mod ie ssk on a diesel so i took the risk. i followed your guide and went all ok....changed gearbox oil and diff oil to redline performance.
however i still get crunchy gear vhanges and at times i have to push gears harder from 5th to 4th or to 3rd...is it due shorter gear shift. im using same gear knob and gaiter. mstyle said with most ssk they hit driveshaft nut once installed is this true?
Post by marco_polo » Wed Apr 03, 2013 2:49 pm
A short shift kit will make changes harder / notchier.
Lots of members have retained their standard gearknob and gaitor, as the alacantara doesn't go with every interior.
Tanda129
Post by Tanda129 » Wed Apr 03, 2013 3:48 pm
so the driveshaft nut should not be catchin u think?
i also fitted cltch stop with steel washers which compliment shifting a lot but the gearbox was notchy before i fitted it...do you think over time time the gear shift will get better...i noticed when its warmer it shifts up really well but dropping gears its really notchy...
Ant
Post by Ant » Sat Jan 25, 2014 3:29 pm
I still can't get the bloody plastic collar to pop up, turn it 90 degrees to right and nothing, anything I am doing wrong???
Some 2.0 Civic thing
Post by Octavius » Sat Jan 25, 2014 3:39 pm
Ant wrote:I still can't get the bloody plastic collar to pop up, turn it 90 degrees to right and nothing, anything I am doing wrong???
It should pull up once the plastic locators have disengaged from the metal housing. Can you see that they are clear ?
Glacier Silver 320d lci M Sport.
Ant
Post by Ant » Sat Jan 25, 2014 3:48 pm
Nope arrows facing forward should come up but nothing, going to break something in a minute
Post by Octavius » Sat Jan 25, 2014 3:53 pm
Try rotating it another 90 degrees. The locators in the metal hub are elongated.
Ant
Post by Ant » Sat Jan 25, 2014 4:02 pm
I have it up, now the bit I was dreading, clip
Post by Octavius » Sat Jan 25, 2014 4:04 pm
Magnetic pick up tool, it's a doddle to do :lol:
Post by marco_polo » Sat Jan 25, 2014 4:11 pm
I use an L shaped piece of thick wire / thin rod.
Slot it through the loop of the clip, then release it with something else. It is a bit like doing keyhole surgery, but not impossible.
Ant
Post by Ant » Sat Jan 25, 2014 4:15 pm
Right old clips lost, oh well,
But new short shift is bent forward or bent back I forget how it was when I took other one off
Ant
Post by Ant » Sat Jan 25, 2014 5:37 pm
Cheers for the tips, All on, looks great and shifts very nice, nearly as good as my old civic. Much easier to rev match on downshift as can throw it in nicer, bit grease on the ball joint has helped make it like new again.
Leejay-B
Post by Leejay-B » Sun Jun 01, 2014 2:11 pm
Great how2.
Ant fitted the kit to his car, then removed it and sold me said car.
Then I bought the ssk off him and had to go through the same procedure on this thread.
All went fairly smoothly but took over an hour. This was due to the really annoying circlip which is so hard to reach. Getting it off without dropping it was painfully slow...
...until I had to refit and that was even harder. No space in there! Glad I had some string temporarily looped round the clip as I dropped it about 3 times.
Le Mans Blue 130i with BMWP bits GONE
dangee
Post by dangee » Sun Nov 13, 2016 1:37 pm
Fitted one of these today and now with run running and driving the gear knob is constantly shaking around, any ideas lads ?
Return to “How To's”
