Inlet manifold removal (N47 123D)
hussy52
Re: Inlet manifold removal (N47 123D)
Post by hussy52 » Sat Jul 08, 2017 7:31 pm
Hi all,
Stuck in a bit of a pickle. Followed this guide and have put everything back together but I can't get the engine to fire. It cranks but no fire. I think I might have messed up the injector cable numbering? Any ideas? Pls.
Sent from my ONEPLUS A3003 using Tapatalk
E87 - 118D - LCI - N47
hussy52
Post by hussy52 » Sun Jul 09, 2017 1:50 am
Hi,
Just note to say managed to sort this out. It was indeed the cabling on the injectors. Schoolboy error for not labeling up before disconnect. Anyone who does this, make sure you mark up the injector connectors!!!
Regards
iscinteianu
Post by iscinteianu » Sun Jul 09, 2017 8:48 am
Question, how do you remove the intake manifold? Tried to do that myself, was somehow stucked. Couldn't release it. So, what to do?
hussy52
Post by hussy52 » Sun Jul 09, 2017 9:10 am
I had this on my first attempt, and gave up. But I decided to give it another go. Basically as long as you have the five bolts undone fully, it will come out. What's snagging is the hoses at the back which are held onto the intake. Also you need to be firm with it. A sharp pull towards you, should release it.
BMW E87 - N47 LCI
Skinzyboy
Post by Skinzyboy » Sun Jul 30, 2017 9:49 am
Any of you guys come across P115C engine code im looking for leaks and cleaning conectors but cant suss it out..
David Michaels
Post by David Michaels » Sun Jan 21, 2018 2:26 pm
My car 320 D 2008 N47D 140.000 miles Just wanted to say followed your procedure and found swirl flaps and bearings all disintegrated, so removed all debris and blocked off rod hole with a nut and bolt and rubber washers .....now goes like a new car ...sooo fast ...so thank you very much
Return to “How To's”
