Fitting e9x M3 LSD to 135i - which diff mounts/bushes?
dino355
Post by dino355 » Tue Apr 26, 2016 10:53 am
I need to know which bushes to order for my 135i when the M3 LSD is fitted.
Do I get M3 items or e82 items?
M2 LCI
Re: Fitting e9x M3 LSD to 135i - which diff mounts/bushes?
Post by marco_polo » Tue Apr 26, 2016 11:08 am
Most people fit the entire E93 rear beam. Do you need to modify a propshaft?
dino355
Post by dino355 » Tue Apr 26, 2016 1:17 pm
marco_polo wrote:Most people fit the entire E93 rear beam. Do you need to modify a propshaft?
Yes the prop is being modified.
What are the advantages of fitting the entire m3 rear subframe?
M2 LCI
0l0dom0l0
Post by 0l0dom0l0 » Tue Apr 26, 2016 1:33 pm
Rear subframe is lighter I believe, but the main reason to do the swap is to get the much better and stiffer M3 subframe bushes that eliminate a lot of the 'loose' rear end that the non m cars seem to suffer from.
B12 KIT with M3 LCA and TS.
dino355
Post by dino355 » Tue Apr 26, 2016 4:04 pm
I've already bought a full set of M3 control arms, subframe bushes and arb bushes. The only bush/mount I've not bought was for the diff.
M2 LCI
Return to “How To's”
