M135i / M140i Rear LED Install Guide (Updated)
Moderators: Lambster, marco_polo, Rich196, Producethis
glen8
Post by glen8 »
Hope this helps a few people as removing the rear light clusters can be tricky. The video at the bottom of this post shows how much better LED bulbs are.
What to buy?
Pre-LCI M135i
2 x 382 clear pairs and 1 x 581 amber pair for the indicators (ie, 6 bulbs in total)
LCI M135i & M140
3 x 382 clear pairs (ie, 6 bulbs in total)
The general opinion is irrespective of any clears pairs used in the factory, buying coloured bulbs gives a far nicer look. I'd recommend purchasing red bulbs for the brake lights and amber bulbs for the indicators even if you have an LCI M135i or M140.
I'd recommend buying some 7mm ferrite cores to prevent any issues with DAB Radio.
https://www.amazon.co.uk/gp/product/B01 ... UTF8&psc=1
Issues Surrounding LED Bulbs
Certain bulbs have various issues, others don't. Hopefully I will come up with a list of recommended bulbs to buy.
Warning lights in instrument cluster - This can be coded out using bimmercode.
Random flickering of the bulbs - Lower quality bulb and should be avoided.
Loss of DAB radio when bulbs in use (ie: reversing) - Resolved by clipping on a 7mm ferrite core to the power cable.
Video Demonstration of Flickering
This video shows LED flickering. Watch the top brake bulb. https://youtu.be/UIOmRE4dV7E
Bulbs with Known Issues
Halfords at £19.99 a pair (5yr guarantee) - 500 Lumens. These bulbs suffer from dab interference and flickering.
http://www.halfords.com/motoring/bulbs- ... -bulbs-x-2
Recommended Bulbs
I'm waiting on some deliveries of the following (thanks to Tom314 for the recommendation)
Twenty20 CREE 382 at £29.50 a pair (3yr guarantee) - 750 Lumens
http://www.autobulbsdirect.co.uk/382-Tw ... -Bulb.html
Twenty20 CREE 581 at £29.50 a pair (3yr guarantee) - 750 Lumens ** Amber for Pre-LCI M135i **
http://www.autobulbsdirect.co.uk/581-Tw ... -Bulb.html
Instructions
Remove the plastic cover and the nut
Using two fingers behind the blue plastic part start to pull in a rocking motion to gradually loosen the gromets. It doesn't take long (under a minute). Keep going until the entire light cluster breaks away from the vehicle.
This is the tricky part if you don't know how to do it. Basically you need the blue plastic in front of the screw, however the bumper is in the way. Put your finger behind the blue plastic, and then pull the bumper away pulling the blue plastic over the screw.
This is where you need to end up, now carefully move the entire light cluster upwards and then once cleared you can pull it away from the vehicle. Unplug the power cable when able to do so.
These are the gromets for reference. You need to ensure the black plastic screws are lined up when putting it back.
Ease out the four clips so you can pull the plastic bulb retainer out.
Twist out the old bulbs and replace with your new LED ones.
Clip on a ferrite core to the power cable.
Put everything back and test.
Video Comparisons
Halfords Bulbs - The right side is LED, the left is standard. You'll notice the indicator and brake light is much brighter and has a thicker spread of light. It's more prominent at night, and really looks the business.
https://youtu.be/eDikKA54HqA
Twenty20 CREE Bulbs - The right side is LED, the left is standard. You'll notice the indicator and brake light is much MUCH brighter due to them having a lumens rating of 750. The spread of light is thicker and has better colour saturation. Looks fantastic!
https://youtu.be/-63tRN9RJCA
ItsMeKyle
Re: M140i Rear LED Install Guide
Post by ItsMeKyle »
That looks way better than the halogen bulbs. Thanks for going through the effort to put this together.
Do you get the DAB interference when braking and indicating as well or just reverse?
17 F21 M140i Manual
glen8
Post by glen8 »
I need to do a few more test runs, but seems to just be reverse.
glen8
Post by glen8 »
I've just ordered various ferrite cores which are being delivered tomorrow. The power cable is not shielded which could be the problem. I'll you know if they resolve the dab issue.
Tom314
Post by Tom314 »
Good guide, I ended up using http://www.autobulbsdirect.co.uk/382-Tw ... -Bulb.htmlthey're quite expensive but no interference or flickering. I used the relevant coloured ones instead of all white which I feel gives a nicer more uniform colour output from the light.
Sent from my Pixel XL using Tapatalk
March 2017 F20 M140i 5dr Estoril Blue & Oyster
glen8
Post by glen8 »
Tom314 wrote:
Sun Jun 11, 2017 7:27 am
They look great. I've ordered a full set and will do a comparison.
glen8
Re: M135i / M140i Rear LED Install Guide (Updated)
Post by glen8 »
Just fitted the twenty20 cree bulbs. See the bottom of the first post for a youtube comparison video. Taken in bright daylight you can still see the vast difference between the standard and LED bulbs. Indicator and brake are not only brighter, but they are much more colourful. Reverse is very very bright and has a lovely cool white tone.
I'm now checking for any issues with them and will report back.
ItsMeKyle
Post by ItsMeKyle »
glen8 wrote:
Thu Jun 15, 2017 5:42 pm
Did you get white LEDs for everything or did you colour match them? do you think the twenty20 are worth the extra over the halford ones?
17 F21 M140i Manual
Tom314
Post by Tom314 »
I fitted the coloured ones and got the same results, theory I went with is that you'll always get more light from the coloured leds as the lens isn't filtering out the majority of the spectrum.
glen8
Post by glen8 »
ItsMeKyle wrote:
Thu Jun 15, 2017 8:54 pm
Coloured, I'll know if they are worth it in a few days when I've properly tested them. They do look good though. I'll try and get a dusk/night time video
Tom314
Post by Tom314 »
Still working fine for me after about 2 weeks of use :)
ItsMeKyle
Post by ItsMeKyle »
Tom314 wrote:
Thu Jun 15, 2017 10:45 pm
No DAB, bulb out or flickering issues?
17 F21 M140i Manual
Tom314
Post by Tom314 »
Nope none, although I don't see them when driving but after fitting I did start the car and stand behind it for 10 minutes watching for flickering and I didn't see any.
ItsMeKyle
Post by ItsMeKyle »
Any update on how the Twenty20 leds are holding up?
17 F21 M140i Manual
Tom314
Post by Tom314 »
Still working fine for me :) I've had the very occasional (twice so far) bulb out warning on the indicators but I've switched the bulbs between sides and haven't had an issue since. If I do get it again I'll get a replacement under the 3 year (iirc) warranty.
