Interior Light's Replacement
Moderators: Producethis, Rich196, Lambster, marco_polo
jamesn186
Post by jamesn186 » Tue Oct 17, 2017 3:21 pm
Hi all,
I am trying to figure out how to replace the interior roof lights in my 2017 116. I cannot for the life of me figure out how to remove the cover to access the bulbs/connections.
Nobody on the internet seems to have ever posted about this certain light fixture.(All i can find is the dome spotlight fixture) Attached is a photo of the fixture i have.
20171017_150838-min (1).jpg (68.3 KiB) Viewed 1301 times
So far i've tried taking the trim off to see if there is something i need to unclip but i couldnt see anything. In regards to the back seat light fixture, there only seems to be one way of doing it and that would be to just pry it off, although i have already put quite a bit of force into trying to pry it off with no luck, i just cant see how the covers would come off normally.
Also i reference to this post viewtopic.php?f=54&t=95672 i have the same thing with my lights, i'd like to know why this happens and if i can change it. If anyone knows?
Cheers.
Re: Interior Light's Replacement
Post by Octavius » Tue Oct 17, 2017 6:08 pm
See if you can find a pic of an uninstalled light unit to see how it clips into the liner. Most likely the lamp holders will unclip from the rear so the unit will need removed.
DEFECTED TO SKODA.
jamesn186
Post by jamesn186 » Tue Oct 17, 2017 7:14 pm
Well thats the issue, i cant find any pictures of this unit assembled or disassembled
fez_7
Post by fez_7 » Wed Jan 24, 2018 6:25 pm
Regarding the rear light I managed to pry it open using some force. The trick is to insert a trim tool (I used the end of a spoon) between the light and the ceiling on the side which is closest to the front of the car. There are 2 metal clips/hooks which you need to slide out. They are about an inch away from the corners of the side facing the front of the car. You must slide these downwards for the light to come out. Unfortunately I applied too much force and lost 1 of the clips inside the ceiling as it popped out. Luckily the light went back in and is secure with just 1 clip.
Regarding the front I tried the same as you and could not work it out. It's probably the same as the rear but I'm afraid of applying too much force and breaking it so I'm currently stuck with a yellow front light whereas I now have a nice bright white Led rear light!
Post by Octavius » Wed Jan 24, 2018 7:52 pm
Remove the front sun visors and the roof lining will drop down enough to allow access to the fixing clips.
DEFECTED TO SKODA.
fez_7
Post by fez_7 » Wed Jan 24, 2018 11:07 pm
Thanks a lot, I’ll give this a go on the weekend and let you know how I get on!
fez_7
Post by fez_7 » Sat Jan 27, 2018 4:28 pm
Unfortunately still no luck with this. I removed the screws on each side closest to the centre and the lining came loose but it’s still stuck where the rear view mirror is. I tried and failed to remove the visors fully as I couldn’t the remove the caps closest to the door?
2013 116D EfficientDynamics
Post by Octavius » Sat Jan 27, 2018 6:22 pm
Stanley knife blade and flip them out.
DEFECTED TO SKODA.
