Modifying headlights with DTM rings
Moderators: Producethis, marco_polo, Lambster, Rich196
SmurfN
Post by SmurfN » Wed Nov 29, 2017 11:34 am
Im laying down the plans to modify my headlights for DTM rings and hopefully add LCI LED brows. to something similiar to this: Image
Plans:
- Paint headlight interior dark grey/black
- DTM light rings
- LCI LED brow
Current headlights on my 06 e87 118d rocking lci stickers: Image
Ive read about the issues seperating the lenses on these headlights, so if anyone has any more tips on this thats much appreciated!
Another option is to buy a set of these lci headlights with the brow and modify these with the dtm rings, assuming these headlights are plug'n'play for my car, anyone know?
https://www.ebay.com/itm/HEADLIGHT-XENO ... wrFtZ~vm2
aj_mckay
Re: Modifying headlights with DTM rings
Post by aj_mckay » Tue Dec 19, 2017 7:40 am
‘LCI’ Headlights (with the brow) are p’n’p in all E8X cars. The brow only lights up on the xenon versions, the halogens are just a dummy brow.
You’ll face the same issues separating either version of the lights, this issue being the ‘permaseal’ that Valeo use to seal the lenses to the headlight assembly. It’s incredibly tough and makes removing the lenses a real challenge. So I’d save my cash and just open the ones you have.
It can be done though, I’ve done a few.
'57 Le Mans Blue 120D E87 | Style 261s
WANTED: E8x headlights - all types required, please contact me if you're selling!
Sonic1506
Post by Sonic1506 » Tue Dec 19, 2017 9:45 am
Not all OEM Xenons with the brow are light up.
aj_mckay
Post by aj_mckay » Tue Dec 19, 2017 9:51 am
But none of the halogens do.
Sonic1506
Post by Sonic1506 » Tue Dec 19, 2017 11:28 am
I didn't say they did?
Roshy281
Post by Roshy281 » Thu Dec 21, 2017 10:24 am
Hey mate I saw a guy who had an E87 with the flat bottom angel eye rings (not sure if DTM) and he can do this job for people.Not only this he offered to add a lci style brow for around £150 to my pre-facelift E87 that has the xenons from factory.
E87 120d 2005
Sonic1506
Post by Sonic1506 » Fri Dec 22, 2017 10:31 am
There's a guy on the Facebook 1 Series page called Zimi Van Ende who can do that.
If you want someone in the UK, I'd recommend EM Tuning. Avoid someone called Toby-E82 on here, avoid Headlight Retrofits and avoid Never Enough Mods (NEM).
SmurfN
Post by SmurfN » Tue Jan 02, 2018 10:44 am
ok, thanks for the input. you have a preferred method of seperating the lens? also if i dont buy a new headlight ill still need to get the brow from somewhere, can i even buy that seperately somewhere?
aj_mckay
Post by aj_mckay » Tue Jan 02, 2018 11:37 am
SmurfN wrote: ok, thanks for the input. you have a preferred method of seperating the lens? also if i dont buy a new headlight ill still need to get the brow from somewhere, can i even buy that seperately somewhere?
I put them in the oven to soften the sealant and then pry them open. Takes a good while and is very tricky.
There’s nowhere reputable that produces the brows alone, as far as I’m aware.
SmurfN
Post by SmurfN » Tue Jan 02, 2018 12:49 pm
i see bavgruppe sells the led part of the brow, https://www.bavgruppedesign.com/product ... led-ae-kit
maybe a possibility to put that behind the sticker or something inside the glass. on the other hand would be a shame to not put the proper brows in if i first open them up.
Jack@AUTOID
Post by Jack@AUTOID » Tue Jan 02, 2018 2:37 pm
I’ve got the pre-LCI xenons. Only interested in adding the LED brow, not the DTM angels.
Best solution? The Zimi Guy will only do them with the DTM angels.
Interested to hear who can do that for £150?!
AUTOID
autoid.uk.com
jack@autoid.uk.com
‭020 7205 2429‬
E81 130i LE
BMWP Short shift kit, Handbrake, Front Bumper, Grilles, Side skirts. 15mm spacers all round. Cruise Control Retrofit. Res delete, 135i BMWP Back Box + few more bits.
Roshy281
Post by Roshy281 » Tue Jan 02, 2018 3:16 pm
Checkout cookiez_customs_ on instagram as he is the one who quoted £150 to add the led brow.
E87 120d 2005
