E88 front lights not working ?
Moderators: marco_polo, Lambster, Rich196, Producethis
jono400
Post by jono400 »
Anyone able to advise on the following got a 2012 E88 120D msport . .,..The headlights / sidelights won't switch on as well as the front / rear fogs. High beam will work if I flash the lights. Worth a check off the fuses and if so anyone advise what / where the relevant one is located ?
Cheers guys.
John
BMW 120 D msport convertible / E88
* Still looking for a set off Depos v2 *
jono400
Re: E88 front lights not working ?
Post by jono400 »
Update.. car is off to the garage on Friday :twisted:
First off all headlights / sidelights / main beam failed to come but you could flash the main beam, had a look at the 40amp fuses within the fuse box behind glovebox nothing immediate showing. started the car up and now as well as the problems listed above I now get a lamp out warning on the dash as well as the indicators on the passenger side front and side not working / others working but running fast... argh !!!!
one consolation is that the drivers side window sticking / failing to drop seems to have cured itself !!
always thought it was French cars that had dodgy electrics !!!!!!
