F20 Cruise Control fitted
Manufactured from end of 2011
BFleming
Post by BFleming »
Today I put cruise control on my F20, and although I had no previous experience of eSys coding, I managed to get that installed & running first time too.
The steps I went through were:
Bought the eSys cable from Amazon (OHP 10122 OBD2 Diagnostic Adapter Connector) along with a USB to Ethernet adapter as my laptop didn't have one (UGREEN USB Ethernet , USB Network Adapter ,USB 2.0 to RJ45 Lan Adapter).
Downloaded the eSys software. I used this guide - I'm sure other guides are available, I'm just stating what worked for me.
Bought the cruise control switches from eBay. There are several different types depending on what steering wheel you have - I used RealOEM to find the correct buttons from my non-Sport wheel. Note although I had a multi function steering wheel (MFSW) I only had the 'LIM' speed limiter button - so the correct part for my car was 61319261859. This is the only BMW part I needed.
I disconnected the battery at this stage before the airbag removal. I'm less worried about exploding the airbag, more about the horn going off during removal!
For the physical install I used this guide.
My airbag was a pain to remove using the slits, so I ended up doing it the way the guide suggested (also shown here: https://www.youtube.com/watch?v=sRnxGSAHNNY which was surprisingly quick & I didn't break/rip anything :D )
The removal of my old switches was really easy, and putting the new switches in was plug & play, then pop the airbag back in & the steering column trims back on - physical job done. Reconnect the battery at this stage, and start the car up. the only errors you'll get at this stage are to reset the time & date. The cruise won't work yet, and your new 'SET' button on the left will act as your old 'LIM' button did.
Coding...
In short, I added code 544 to the Vehicle Order (VO, or in German FA). Using the above mentioned guide again, Page 28 onwards, I fired up eSys, selected my car (F020, which is a F20 1 series) and followed the guide. All was crystal clear in the process right up to the coding of individual ECU's - that's where it became 'open to interpretation', but I used the information from the cruise control retrofit guide to code the following ECU's:
- FEM (body)
- ICM
- BCKOMBI (the instruments, sometimes just called Kombi, but it was labelled BCKOMBI in my car)
At this stage I got errors related to tyre pressure control as it needed to be reset (the instruments forget what temporary information they have stored, like bord computer / trip / tyre pressures.
Quick test drive afterwards & cruise works perfectly, I get all the correct messages on the display, the green cruise control warning light and the red or green marker on the speedometer. The jockey wheel works perfectly too for increasing / decreasing the speed. All in all I'm very happy with this, especially as the cost was under £100 (incluing the eSys kit, which I will undoubtedly use again).
Hope this helps someone, but post a message if you need any clarifications.
2013 BMW F11 525d SE
2018 Volkswagen Golf GTE Advance
2000 Porsche 986 Boxster 2.7
1998 Kawasaki ZX6R G1
KFY_ibo
Re: F20 Cruise Control fitted
Post by KFY_ibo »
cheers for that nice little read
2013 Alpine White 116i M-Sport #us11boo
texasjohn
Post by texasjohn »
Nice one
Thanks for the write up
happy_micky
Post by happy_micky »
Nice write-up mate...
No cruise control is the only thing that I didn't like about my baby bmw, got every spec I wanted on the car and thought cruise control was standard... and it wasn't...such a pain driving long distance after getting used to wife's adaptive cruise control on her car...
Where about are you located mate, I was thinking if you could do mine for a fee?
oxfordshirerob
Post by oxfordshirerob »
happy_micky wrote:
Thu Jan 11, 2018 4:13 pm
Hi micky, if BFleming isn't able to assist, I can highly recommend Wibbles (he's on this forum). He did mine all remotely (he's actually based in the North, where as I am in Oxfordshire). Send him a PM and I am sure he can sort you out. I fitted the buttons on my wheel (took me about 30 minutes from start, to wheel off, new buttons on, wheel re-fitted), I hadn't done it before, so really was easy. Wibbles then remotely coded it in an evening very quickly remotely. Job done! I've been happily using Cruise Control ever since.
BFleming
Post by BFleming »
I'm in Hertfordshire! Happy to help as required.
happy_micky
Thanks for the reply buddy, I will give it a tempt myself and post back! controls on the way now :spotman:
happy_micky
oxfordshirerob wrote:
Thu Jan 11, 2018 5:37 pm
Thanks for the recommendation mate! So promising to hear that the physical part isn't that hard to do. I will give it a tempt and see if it didn't work I will ask BFleming/ Wibbles for help!! Will post pics up!
Nice write up again BFleming!
oxfordshirerob
happy_micky wrote:
Fri Jan 12, 2018 12:36 pm
Hardest part by far was getting the current airbag off, as hadn't done it before, was surprised by how much effort I had to put on the screwdriver to release the clips as went through the back of the steering wheel method........had I seen the link (posted earlier in this thread) for the alternative method, I would probably of gone down that route!
Hope you get it sorted and enjoy the CC.
BFleming
Post by BFleming »
Depending on what year & specification your 1 series is, there are a lot of different button sets available. Just make sure you've ordered the correct ones.
MikeMerton10
Post by MikeMerton10 »
Hi
New to here and BMW in general!
Would either BFleming / Wibbles be willing to give a hand with mine if I bought the spare parts... thinking of getting a spare steering wheel from a breakers yard to harvest the steering wheel controls from.
I wouldn't be comfortable doing the physical fitting or the coding on my own (terrible noob)
Thank you,
Mike
BFleming
Post by BFleming »
I can help, but bear the following in mind:
  • I work overseas a lot, so may not always be available
    I don't do remote coding - Find Luton Airport on a map, and I'm very close to there (when I'm there)!
    There are different steering wheels for the F2x models, with different buttons, so be very cautious in choosing the correct parts
So as long as you're good with all that, I can help :mrgreen:
happy_micky
MikeMerton10 wrote:
Thu Sep 12, 2019 11:12 pm
Hi
Thank you,
Mike
It isnt really that hard to do the physical parts... There are 2 holes on the back of sterring wheel for the fast release of the air bag and the is just couple of small screws and the plig and play... I have mine coming off this week as im returning the car on friday for a m2c... Let me know if you want the buttons it wyll be a lot cheaper than buying a sterring wheel.. Then you can get either guys from the post to do the codings for you... Pm me for more info
BFleming
Post by BFleming »
happy_micky wrote:
Tue Sep 17, 2019 12:33 am
Are you going to remove the coding too? I imagine swapping out the buttons & not sorting the coding will cause the LIM button to not function properly.
happy_micky
BFleming wrote:
Tue Sep 17, 2019 11:54 am
Car went into bmw today for a service and reprogramm... The cruise control wasnt working so the computer was reset back to normal so I needen't worry, car going back to bmw tomorrow for the new m2c
