recent experience with a 116d B37
Manufactured from end of 2011
poiuytre111
Post by poiuytre111 »
I offer the following comments for any of you considering an entry-level BMW diesel.
I recently bought a 20k mile 116d with the 1.5l B37 3 cylinder engine having previously had several M47 and N47 cars including most recently an E81 120d. I chose the 116d as I spend 99% of my miles cruising motorways at moderate speeds these days and was happy with the performance offered - also a 116d became available in the right spec before I found a 118d or 120d so I pulled the trigger.
Since driving the car for several '000 miles I very quickly came to realise that there was a factor I should have considered that significantly changes the nature of the engine and for the worse. I am referring to the inevitable effects of having only 3 cylinders and therefore fewer firing pulses per '000 rpm. Its not about power its about firing pulses.
My 116d runs smoothly enough but idles at 1000 rpm rather than the ~800 I was used to but more significantly it does not want to pull even gently from below about 1400 - 1500 rpm. When you add the fact that the 116d uses a 40mph/1000 top gear/final drive you find that you need to change to a lower gear no matter how gently you are driving, when speed limits take you below about 60 mph. For the record, the 116d can be usefully more frugal than my previous 120d E81 but anything more than very gentle driving wipes that benefit out, taking me back to the still very good economy I was used to with the more powerful car. So, while I am happy with the 116d now I am used to its foibles, I would add my voice to those who say that a 118 or 120 may be a more pleasant car to drive and most of the time is just as frugal. Would I buy the 3 cylinder car again ? It would need to be a very good deal !
2016 116d Sport
2013 X3 Sdrive
2006 Volvo C70 T5
stevesurrey
Re: recent experience with a 116d B37
Post by stevesurrey »
I think its all down to power:weight ratio. A low-powered engine in a relatively heavy car won't make for great drivability nor good fuel consumption when pressing on.
jason@bwchiptune
Post by jason@bwchiptune »
If you remap the car you will gain a lot more torque
This is what is needed as you need more lower end torque
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE)and Cas units.
BMW Ecu repairs.
BMW remote Keys made and cut same day with or without car even if all keys lost we can supply you a key like the dealers do.
Key data fixed for non starters or when theft attempted.
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used).
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars.
DPF repairs fixed without the need of removal of its guts or replacement.
40% of my work is repairing the problems that are caused by other tuners remap
For more info look in our section under sponsors on this forum
UK
0208 561 1818
07831 103030
Hayes
UB3 1BB
or
Spain
Orihuela Costa
+447831103030
martin10chk
Post by martin10chk »
Very useful and informative post. It is clear that fuel savings from lower powered engines are largely illusory. As soon as you demand more than nominal power from them they rapidly become less economical. I have tried a number of 3 cylinder engines and always find them compromised compared to 4 cylinder counterparts.
Current: MG 2015 M135i - Auto - ProNav - HK - Adaptive - PDC (f + r) - MP LSD
Previous: Golf Gti vi, BMW e9x 330i touring, BMW e90 325D (+ map)
SamM140
Post by SamM140 »
My biggest gripe with this engine, is that it so unrefined.
A colleague was a 116d and the gear stick vibrates so noticeably when idling and sounds really course. The petrol version seems much nicer (had it in my other half’s F56 MINI).
2019 M140 Shadow Edition
Plus my other half’s 2007 116 cheapy project
flyboy777
Post by flyboy777 »
Kirito101 wrote:
Wed Sep 04, 2019 12:28 pm
I think the 116d with around 115bhp is underpowered.
Def worth to try the 118d which is also the same engine but more bhp and pull better
118D is 4 cylinders not 3. B47 2 litre same as 120D, not B37.
At least the 18 plate one I drove last week was.
2017 M2 LCI.
2015 F31 320D. JF Automotive remap.
2007 123D. P-Torque remap.
mupet0000
Post by mupet0000 »
I had an automatic 116D Shadow as a courtesy car recently. My car is quite similar but i have the 118i, the car felt so much worse to drive than mine. The engine runs out of steam very quickly, I don't know what the manual is like but the auto gives it quite a good push from a standstill and low speeds so it's good around town but at higher speeds the pick up is very sluggish, the faster you go the worse it becomes. I did find it strange how much I disliked the car compared to my own considering it's almost the same car just missing a few options, the engine really made a big difference.
The petrol seems a lot more refined and it sounds a lot nicer too, although fuel economy also suffers if you drive it any harder than a grandma, although if you drive gently you can get very good economy.
On the other hand I also had a 118D Shadow courtesy car earlier in the year and that's what made me want the car I eventually got. The 118D felt a lot better to drive, the pickup was always good, it was a manual and it cruised very nicely at 70 in 6th, it also had a good amount of torque to be able to just leave it in 6th at lower speeds, although the auto rev matching made it quite easy to shift down quickly anyway. Also it idled at 800rpm like you'd expect.
Overall I wouldn't even consider a 116d based on my experience. Out of all 3 engines I would pick the 118d, but I have the 118i as I do an awful lot of stop-start driving, the vast majority of my driving is short town journeys so a diesel isn't a good idea for me.
2019 F20 118i LCI2 M Sport [Shadow Edition - Black 18" Wheels, HK, Leather, M Sport Brakes, Extended Storage, Sun Protect Glass, Cruise, Rear PDC] - Auto - Mineral Grey - Folding Mirrors, Black Panel, Pro Nav Retrofit, Automatic A/C, Heated Seats.
tonirai
Post by tonirai »
Kirito101 wrote:
flyboy777 wrote:
Wed Sep 04, 2019 8:47 pm
I see, sorry for my eror as I thought the b37 was also a 3 cylinder engine
You're mixing all up...
What he told you is the 118d is 4 cylinders because it's a B47.
It's not a 3 cylinder (which yes, is the B37).
125d, 120d and 118d are 4 cylinders B47;
116d and 114d are 3 cylinders B37.
mupet0000
Post by mupet0000 »
Kirito101 wrote:
Thu Sep 05, 2019 9:38 am
Good input, if it wasnt for motorway miles, would you still pick the 118d over the 118i? In addition, in regards to power, which engine between the 118d and 118i feels more responsive ?
It's sort of hard to judge as the 118d I drove was a manual and my 118i is an auto. It's quite interesting because I did drive a manual 118i early last year and honestly it felt slower than my current 118i with an auto box, the auto box makes a big difference and I think the 116d in manual form would feel worse. The 118d with the manual compared to my 118i with an auto, the 118d definitely felt more powerful and responsive, I think if it was manual vs manual it would be a lot quicker. It pulled well and unlike the petrol, it didn't need to be revved out to get the power down.
Never got a picture of the rear of that car :(
That's really what kills the fuel economy on the 118i, you can make good progress but the auto box will be shifting you at 6K, although it sounds great :lol:
If it wasn't for my stop-start short journeys then yes I would pick the 118d, the improved fuel economy and torque wins me over even if it doesn't sound nice.
