Which is the better clear coat?
Manufactured from end of 2011
YouthAVFC
Post by YouthAVFC »
steveespania
Re: Which is the better clear coat?
Post by steveespania »
For DIY jobs definitely the 2k lacquer BUT there is no such thing as a totally clear lacquer and if the BMW one is OE then that may be the best one to use. Also remember that once you've released the valve on the 2K lacquer, it's got a short shelf life.
2016 118d Advantage Navi Auto, Glacier Silver, LED Headlights, Eton b100xw door speakers.
Post by Octavius »
I would also experiment with the cans to see which has the best spray pattern and how quickly it sprays.
Post by marco_polo »
I'd go for a thin coat of 2K. I'd heat the can up first by sitting it on some warm water (increases the pressure for a better mist).
swanny71
Post by swanny71 »
Have used the BMW clearcoat on a wing mirror scuff before, the spray pattern was crap, lots of splatter. As above, test before using on your ‘good’ piece.
Current: M135i manual
Previous: 1M, 130i, Exige V6, TVR's, e90 M3, 156 GTA, 182 Trophy, 306 GTi-6 + others (some crap, some not so crap)
Autosri
Post by Autosri »
The easiest/best finish I can get from normal rattle cans is Halfords stuff
The bmw one is just 1k clear so nothing special
The 2k one if it’s polyurethane is highly toxic and you need to do some research on it before using it
YouthAVFC
Post by YouthAVFC »
Thanks for all the replies, the warm water trick I’ll remember for when I come to use it
Autosri
Post by Autosri »
Warming the paint is useful but also warming the part works well even just a hair drier is enough
