Bmw 125d 2015 Facelift Swirl Flaps Problem
Manufactured from end of 2011
HamzahV
Post by HamzahV »
Hi guys, i’m new to this forum and just needed some help regarding my 125d. Its the 2015 lci model so i’m guessing the newer b47 engine?
However the issue i’m running into is turbo underboost. At full throttle/flooring it, the car runs a dream but lower down there is little power and the drive train fault ends up coming up restricting performance.
Is there any fixes to this or anywhere I should look first? Any help would be greatly appreciated.
Thanks guys!
tonirai
Re: Bmw 125d 2015 Facelift Swirl Flaps Problem
Post by tonirai »
Are you sure about swirl flaps issue? Have you connected the car to diagnose the problem?
EGR fault can have those similar symptoms... And there are recalls for it, did yours have it done?
HamzahV
Post by HamzahV »
I checked the vin and theres no outstanding recalls on the car?
And the mechanic did say the swirl flaps were pretty covered in carbon so i’ve had a tuner delete the software so they dont work anymore or cause any problems. Seems to be a vacuum leak somewhere
Tiffster
Post by Tiffster »
The only way to check the swirl flaps for carbon build up is to completely remove the inlet manifold. Did your mechanic do this ? It's about 2-3 hours labour.
When the drive train fault appears, what fault codes are logged (presuming you have had it scanned)
The 125D is VERY common for the small turbo seizing, i've replaced loads due to it. Very little to zero low down power but mid and top end range is fine as the second larger turbo kicks in.
F20 120D, Flap delete, EGR delete, 370mm MPBBK, MP Carbon Interior, LCI Steering wheel Retrofit
HamzahV
Post by HamzahV »
Its P0299 coming up. Apprently a vaccuum leak according to the remap specialist fixing the car
Tiffster
Post by Tiffster »
P0299 will most likely be the pressure converter for the small turbo, a vac hose (although unlikely on 2015) or the small turbo itself.
HamzahV
Post by HamzahV »
Turned out it was a hose that was pinched, vacuum pressure back and cars back to its normal self! Thanks for the help
