Burnt light connectors
Manufactured from end of 2011
benhowarth6
Post by benhowarth6 »
So last week I had intermittent light errors for the rear left. It started with just a few then all lights including the LED strips stoped working.
After removing the rear left cluster I noticed the middle ground pin had burnt completely. I repaired that by running a new ground wire bypassing the connector, then soldered directly to the ground inside the cluster. All has been fine since.
Today however the right side has done the same thing, which I’m planning on repairing tomorrow in the same way.
Is there a bigger issue that could be causing this perhaps that I should check for? I’ve not found much information apart from some F30’s which have done the same.
I’ve attached some images of the damaged connectors.
Car is a 63 120d m sport with xenons so it has the rear LED lights.
2013 F21 120d M Sport, Black, Sport Auto, M Sport Plus, Sun Protection
2012 F21 118d M Sport, White, Manual, Heated Leather, Driver & Interior Comfort Package, Sun Protection
Re: Burnt light connectors
Post by Octavius »
That sort of damage is usually cause by a loose connection. Being a poor contact it’s causes resistance and then heat.
tweeky
Post by tweeky »
Is there a seal missing from the plug.
Current 2018 F22 M240i Sunset Orange Black leather with lumber support,Pro Nav, Adaptive LEDs, HK, Sunroof F&R PDC.
Gone 2015 F22 Melbourne Red 220D loaded with many extras.
Post by Octavius »
Why are the light units so dirty on the inner face ???
