F20 Fuse Diagram
Manufactured from end of 2011
VFRMark
Re: F20 Fuse Diagram
Post by VFRMark »
Luksas wrote:
Sat Aug 25, 2018 1:28 pm
VFRMark wrote:
Sun Aug 19, 2018 4:34 pm
Help going away for 3 weeks and want to remove a fuse that will prevent the car starting, i can see a "Stop/Start" fuse but not sure if this is only for the stop/start functionality or stops the car starting from cold.
if anyone knows it saves me the pain of removing fuses one by one and testing
thanks
Removing fuse 165 (or 149, 150, 151 depending on engine version) should disable fuel pump. Remove it and try start the car. This is what i have done in the past.
Wow great, that has double benefit in that I can leave the solar panel conected - many thanks
moghm
Post by moghm »
HI guys, very useful but need further help. My rear demister does not seems to be working. I dont know why BMW have made this so complicated. Anyone know if fuse 80 is the rear demister one, if so, am i right to assume its near the battery ??
Many thanks.
LittleWellsy
Post by LittleWellsy »
moghm wrote:
Mon Dec 03, 2018 1:12 pm
Many thanks.
I’m also in need of this info for her 116i, however I do know that fuse 80 (30 amp) is the rear demister, but can I heck find the fuse box it’s in.
LittleWellsy
LittleWellsy wrote:
Tue Dec 11, 2018 12:39 pm
Many thanks.
Found on another post that the boot lining needs be be removed on offside, exactly where it says on the diagram. Expected it to be under the small storage compartment, but that would've been too easy.
Raygbmw1
Post by Raygbmw1 »
Try this site https://www.newtis.info
It’s a beta testing for now and I think it’ll be made user pay in the end of the testing phase.
Anyone can search the wiring diagram of BMW cars there and the fuse number that connected to the ECUs.
14TDC
Post by 14TDC »
Hi, guys!
I have a 2016 f20, and my rear washer stopped working (no sound whatsoever when I pull the stalk). I want to check the fuse, but looking at the diagram doesn't help: is there just one fuse for both windshield washer and rear washer? What is the number for this/there fuse(s) - what does the car on jack icon mean?
Many thanks
Marian
catalz
Post by catalz »
MrPinny wrote:
Sun Sep 30, 2018 12:50 pm
Can anyone recommend a switched and constant fuse as I’m trying to hardwire a Blackburn power magic.
Thanks in advance
Did you ever figure this out? Looking for a fuse with constant power. Currently wired to the lighter fuse but causes it to reboot when stop start engages.
MrPinny
Post by MrPinny »
I ran it straight off the battery in the end.
drsammyj
Post by drsammyj »
Peter9588 wrote:
Thu Sep 07, 2017 9:58 pm
Can anyone recommend a fuse to wire a dash cam into??
Thanks,
Peter
Which one did you use in the end?
ghostdriver
Post by ghostdriver »
Any chance we can add relays on to this, would love to know which one is fuel pump and starter relay, handy for security
EddieT
Post by EddieT »
Hi,
Can anyone tell me which fuse is for the Bluetooth/stereo/entertainment system?
Playing iPod and it was showing a difrent album to what was playing, also when I get s text message I see the envelop on the screen but only shows old messages when I click on it.
Any suggestions much appreciated.
Eddie
Dazzles
Post by Dazzles »
Wire diagram is in the boot under what is/was the spare tyre cover. Very handy.
That dickhead in the orange bmw
gdhillon
Post by gdhillon »
I have a 116i (2014) and cannot seem to work out what fuses are for my horn as it has stopped working. The horn symbol on the diagram doesn't have a fuse location listed next to it. Any help please? Thanks
gdhillon
Post by gdhillon »
Dazzles wrote:
Fri Sep 27, 2019 12:54 pm
The horn symbol doesnt have a fuse reference next to it?
gdhillon
Post by gdhillon »
gdhillon wrote:
Thu Oct 24, 2019 10:06 am
