E8* coding - still NCS and Virtual Computer or another option yet?
docwra
Post by docwra » Mon Feb 19, 2018 2:20 pm
Ive just fitted BMW Performance seats in my E82 135i and the car is telling me the airbag/seatbelt tensioners are now not working, Id read before fitting that this was likely to happen and can be coded out.
When I previously coded out my e-diff I used the software that came with the D-CAN cable, so effectively had a virtual computer running NCS Expert. This worked fine, but took up a lot of my laptop's Hard Drive and when I recently reformatted I obviously lost everything. If I can avoid id rather not stick 10GB of software back onto the machine so is there any way of coding without all of this?
I actually bought a version of NCS from NCS-expert.com that is supposed to run without VC but it is loading up incorrectly, one of the .rar files is corrupted and one of DLL's apparently isnt written for Windows, even when I change compatibility settings.
I know I can pay someone to code remotely but when Ive got the D-CAN and am comfortable with the coding itself it seems to make more sense to give myself the ability. :)
bjt
Re: E8* coding - still NCS and Virtual Computer or another option yet?
Post by bjt » Wed Feb 21, 2018 7:41 am
NCS is still the most capable tool for coding the older cars. The issue is that it doesn't work well with newer/64 bit Windows hence the virtual machine.
Getting a cheap old laptop with Vista 32 bit just for coding is a good option.
smith-n7
Post by smith-n7 » Wed Feb 21, 2018 10:20 am
How strange, I have mine running on a new'ish laptop with Windows 10.
No issues whatsoever :)
24 valves, no turbo.
docwra
Post by docwra » Thu Feb 22, 2018 2:22 pm
See, this is what Id read, that it can be used on 64 Bit as well, you just need to change compatibility settings on one of the executables.
Ive gone back to the software resaler to ask them what the score is, if that doesnt work then it might be cheap laptop time I guess.
docwra
Post by docwra » Mon May 14, 2018 2:46 pm
Bump, any more suggestions? Wibbles is saying he will need a 32 bit machine at this end to do it remotely and BMW will only code the car back to standard.
I really dont want to have to buy a 32 bit laptop to change one setting, surely there must be other alternative people or software to do it?
smith-n7
Post by smith-n7 » Mon May 14, 2018 6:29 pm
Jimmy at Cableshack
That is who I purchased the software and cable from. Running NCS Expert, INPA, Tool32, WinkFP, NCS Dummy on Windows 10 without any issues.
Contact him. He's very helpful.
https://www.cable-shack.co.uk/
docwra
Post by docwra » Tue May 15, 2018 1:59 pm
Jimmy at Cableshack
Argh, thats where I got it from in the first place :cry:
Cheers though, Ill give him a shout :)
smith-n7
Post by smith-n7 » Tue May 15, 2018 4:28 pm
*deleted duplicate*
smith-n7
Post by smith-n7 » Tue May 15, 2018 4:30 pm
Either get a PC that’s up to the job or take the car to someone to code.
10GB space really isn’t a lot of space nowadays.
Wibbles
Post by Wibbles » Fri May 18, 2018 3:37 pm
I can probably code this now without having NCS installed on the local machine at the customers end. I do all the F-Series cars like this now and it's way less grief for my customers.
If you are willing to be a guniea pig and work with me for a couple of hours to get it working I'll do the coding free of charge.
BR Diagnostics & Retrofits
BRD on Facebook
docwra
Post by docwra » Wed May 23, 2018 8:49 am
Thanks for that Wibbles but I contacted Cable Shack and Jimmy sent over a link to 64v Bit version of BMW Tools. Not connected to car yet but it all seems to be working fine, cheers to Jimmy and Cable Shack :)
Now, anyone got a list of the codes? :lol: Pretty aure I just need to add RECA+ for the performance seats but if anyone knows different ..........
docwra
Post by docwra » Mon Jun 04, 2018 1:57 pm
All sorted, the 64 Bit version worked handsomely and once Id remembered to D/L a driver for the DCAN Cable :oops: it was pretty much plain sailing (other than car battery going flat halfway through)
For the record to add BMW Performance seats (with heat and airbags) its as easy as adding +RECA to the VO :thumbs:
docwra
Post by docwra » Wed Aug 01, 2018 3:10 pm
See last note, I got a 64 bit version of the software, downloaded a new driver for the DCAN cable and then did it myself :)
Return to “Coding/Software”
