Coding in Central Scotland
alex020869
Post by alex020869 » Sat May 13, 2017 6:30 pm
As per the title.
Can anyone recomend someone who can do coding in Central Scotland, West Lothian to be more precise but willing to travel a bit for someone good.
M235i Melbourne Red.
Chris5188
Re: Coding in Central Scotland
Post by Chris5188 » Mon May 22, 2017 2:00 pm
What you looking for ? What car you got? Based in Cumbernauld.
'65 M135i LCI 3Dr Estoril Blue - Sports Auto, Pro Nav, Drivers Comfort, Sun Protection, Harman Kardon
Better asking what it does not have fitted.
GeoffCollins
Post by GeoffCollins » Mon May 22, 2017 3:16 pm
You could always look into BimmerCode if you have a Fxx bmw :)
cheap and has loads of options for coding your car :D
M135i (2014 Manual) - Custom Stainless Exhaust, JB4, BMS Intake, M4 LCA, M4 Front Pads, MeisterR Coilovers, Cades Bern Wheels, Reiger Diffuser, Maxton Splitter, Double Slat Grills, M4 Mirror Caps
D6EML
Post by D6EML » Mon May 22, 2017 10:29 pm
As per the title.
I don't do coding but I'm from bathgate , where you from mate ?
Dean
AW M2 lci
alex020869
Post by alex020869 » Tue May 23, 2017 9:48 pm
I was thinking of getting rid of the stop-start function and was thinking about putting LED's in the indicators so would need the bulb check function disabled.
I have a 235i. Really like it.
Have you coded a lot of things in yours?
[quote=alex020869 post_id=<a href="tel:1277893">1277893</a> time=<a href="tel:1494696620">1494696620</a> user_id=31047]
As per the title.
Dean
[/quote]
I'm also from Bathgate Dean. Need to keep an eye out for you.
Chris5188
Post by Chris5188 » Wed May 24, 2017 9:41 pm
Can do everything except update software :) - I have done or tried most of what you can get for the Fxx platform. :spotman:
alex020869
Post by alex020869 » Thu May 25, 2017 8:28 pm
What have you coded on yours then. Anything you would especially recommend? Judging by your signature that thing of yours is anything but standard :D :D
Chris5188
Post by Chris5188 » Fri May 26, 2017 12:11 pm
It has some surprises up its sleeve :D - looking for new shoes at the moment. Thinking 19" BBS CH-Rs to set it off.
Coding Recommendations
Seatbelt warning turned off
Fold mirrors on Lock (instead of holding) - (Requires Folding Mirrors)
Horn on Lock
Number of Flashes on Lock or Unlock (if you want to make 2 lock 3 unlock)
Increase brightness of daytime running lights (Front)
Door LED turn on when you engage reverse
indicator amount on tap
Switch off Start/Stop
DVD in Motion (Requires Pro Nav)
Save Videos to Hard-drive (Requires Pro Nav)
Digital Speedo
MegaMinion
Post by MegaMinion » Wed Jun 07, 2017 7:48 am
Just seen this. I'm just across the Forth in Inverkeithing, I've got Carly which I think should do your basic coding. I've only coded on my E82 which doesn't have as many options as the F series. But if someone can confirm that Carly will do it I'm happy to do it for you.
2008 E82 N54 135i
C9LFS
Post by C9LFS » Tue Jul 17, 2018 7:32 pm
Hi Chris5188 have u coded a used module into an fXX
ive got an F01 730d sport and SZL module has failed replacement (used) is ordered should be with me Thursday
is this something you could help with the dealer where I am probably won't even look at coding in a used module
and will want me to fork out close to a £1000 to supply fit and code which is a complete rip off as I have had the unit off and it
took me literally 20 mins off - check wires connectors- then refit
If not do you know anyone else that could code this either in person or remotely
thanks in advance Colin
Wibbles
Post by Wibbles » Fri Jul 20, 2018 1:49 pm
I could probably help with that.
BR Diagnostics & Retrofits
Apple Carplay - ONLY £89 - BabyBMW Special offer!
FULL SCREEN CARPLAY NOW AVAILABLE!
BRD on Facebook
jono400
Post by jono400 » Tue Aug 28, 2018 11:38 pm
You still down in inverkeithing mate ? Up here in Dunfermline and could do with getting the low voltage check on start up for the headlights coded out on my E88 to enable the use off LED headlights.. able to help me out ?
BMW 120 D msport convertible / E88
* Still looking for a set off Depos v2 *
RickN55
Post by RickN55 » Wed Aug 29, 2018 1:18 pm
Horn on Lock
Digital Speedo
Horn lock? Did you do this with Bimmercode?
jono400
Post by jono400 » Mon Sep 03, 2018 6:16 pm
Anyone in edi / fife area able to help me out with a simple coding on my E88 ? located in Dunfermline but will travel within reasonable distance .
cheers guys.
john
JSizzle
Post by JSizzle » Sat Nov 03, 2018 8:04 pm
I'm looking to get my radio coded to enable the Aux menu on the professional radio I've just installed to replace the Business Radio. I would be grateful for any help.
Return to “Coding/Software”
