Best tyres
Get your M2 fix here
boldy1
Best tyres
Post by boldy1 » Sun May 06, 2018 5:26 pm
Time has come to replace my rear tyres, what I'd like to know is what sizing works, and what's the best tyre. I have the cont sc3 on .
DaleB90
Re: Best tyres
Post by DaleB90 » Sun May 06, 2018 7:50 pm
Personally I’ll be going for MPSS when the time comes. 255 or 265/35 front and 285/35 rear, front sizing will depend on if I have camber plates fitted or not.
M2 LCI DCT- B16 PSS10’s, BM3 stage 2, downpipe, Pure turbo inlet, panel filter, vrsf HD Intercooler.
M135i 8AT - gone
Np01
Re: Best tyres
Post by Np01 » Sun May 06, 2018 8:14 pm
As I haven’t got the m2 I probably shouldn’t comment, but you should look at the MPS-4S as they are the replacement for the MPSS and meant to be a really good tyre, only available in 19s and above
M135i Manual, mineral/oyster, MHD stage 1, carbon mirrors, MPE, full carbon trim, double slat grille, HK, pro Nav, Alcantara wheel, AC roof spoiler, on MPSS, Forge Motorsport Charge Pipe
swanny71
Re: Best tyres
Post by swanny71 » Sun May 06, 2018 8:27 pm
MPS4S on my 1M and very happy. Same sizes as OEM on both cars.
Just as grippy in the dry as MPSS, better in the wet and less road noise. Not noticed any excessive flex in sidewall as some claim they can.
Haven't tried them on track so can’t comment in that respect.
Current: 130i & 1M
Previous: Exige V6, TVR's, e90 M3, 156 GTA, 182 Trophy, 306 GTi-6 + others (some crap, some not so crap)
OrtonM135i
Re: Best tyres
Post by OrtonM135i » Sun May 06, 2018 8:44 pm
You’ve got the choice of standard MPSS, Pilot Cup 2 or MPS4S in my opinion. Theres contis and others etc but the above seem most popular by reviews
Ive gone for Michelin Pilot Sport 4S - 255/30 front and then standard 265/35 rear.
The grip is insane, only ever known Michelin’s Cup 2’s on an old Porsche grip/handle better. The MPS4S are unbelievable for traction and grip in the dry and still very good in the wet. I personally couldn’t be happier with them and highly recommend them about 7,000 miles in
I can push the car 5-10mph faster in corners as the 4S’s gives so much grip and confidence even on British A and B roads.
I went for plus size, slightly wider and lower profile on the fronts as some had fitted the standard sizes on the M3’s and reported they were a bit too soft/lacking stability.
Only thing I will say is that I am going to buy 275/30 for rear once mine have worn as they maintain or improve ride comfort over oem size MPSS or contis but the MPS4S seem better and more direct in the 30 profile as well as more stable but still very good ride and excellent NVH.
2017 M140i auto
2013 M135i auto
2010 Mini JCW
2010 123D Msport
2007 Porsche Cayman S
2011 135i Coupe DCT
2007 Mini Cooper S
DaleB90
Re: Best tyres
Post by DaleB90 » Mon May 07, 2018 5:01 am
The grip is insane, only ever known Michelin’s Cup 2’s on an old Porsche grip/handle better. The MPS4S are unbelievable for traction and grip in the dry and still very good in the wet. I personally couldn’t be happier with them and highly recommend them about 7,000 miles in Image
Interesting about the reduced profile as the mixed reviews on the PS4S is what put me off them. Some say they are amazing then some say they can feel a bit of wallow when cornering.
I suppose when up sizing the width the difference in side profile will be minimal even though you are dropping it by 5%.
M135i 8AT - gone
CaptFish
Re: Best tyres
Post by CaptFish » Mon May 07, 2018 8:00 am
boldy1
Re: Best tyres
Post by boldy1 » Mon May 07, 2018 11:21 pm
Sorry for the late response, I accidentally decided to do a front flip on my mtb this morning. So the michelin look like the best option. But my front tyres have plenty of life left in then will miss matching affect handling
boldy1
Re: Best tyres
Post by boldy1 » Fri May 11, 2018 3:21 pm
So I have just ordered ps4s 275 35 will these fit ok would appreciate your views
boldy1
Re: Best tyres
OrtonM135i
Re: Best tyres
Post by OrtonM135i » Fri May 11, 2018 3:38 pm
boldy1 wrote:So I have just ordered ps4s 275 35 will these fit ok would appreciate your views
Yeah these will fit fine,
you can go up to 285 wide on the stock rear rims and up to 265 wide on front stock rims
2017 M140i auto
2013 M135i auto
2010 Mini JCW
2010 123D Msport
2011 135i Coupe DCT
2007 Mini Cooper S
boldy1
Re: Best tyres
Post by boldy1 » Fri May 11, 2018 3:42 pm
Thanks, will they improve grip
OrtonM135i
Re: Best tyres
Post by OrtonM135i » Fri May 11, 2018 3:46 pm
boldy1 wrote:Thanks, will they improve grip
Yes as you’ve got an extra footprint of 20mm across the rear tyres and the PS4S is incredibly grippy.
What tyres were you on previously? are you upgrading your fronts at the same time or relatively soon?
2017 M140i auto
2013 M135i auto
2010 Mini JCW
2010 123D Msport
2011 135i Coupe DCT
2007 Mini Cooper S
boldy1
Re: Best tyres
Post by boldy1 » Fri May 11, 2018 3:51 pm
I have the sport contact 3 on the front, had the same on the rears too, the front still have loads of life left , I asked the garage I ordered them from if the different tread patterns would be ok and he said they would be fine. What's your take on this?
OrtonM135i
Re: Best tyres
Post by OrtonM135i » Fri May 11, 2018 4:00 pm
boldy1 wrote:I have the sport contact 3 on the front, had the same on the rears too, the front still have loads of life left , I asked the garage I ordered them from if the different tread patterns would be ok and he said they would be fine. What's your take on this?
It’s no major issue as this is exactly what I did, had oem Conti 3s on front and my new MPS4S on rear until a few weeks later got the fronts changed to MPS4S as well.
Basically with wider grippier rears you’ll get fantastic rear traction but this pushes the balance more to understeer until you get the fronts changed as well.
No biggie though you’ll just adapt your driving style slightly to compensate
Get the fronts done soon and you’ll see how much faster you can take corners than the standard tyres Image
2017 M140i auto
2013 M135i auto
2010 Mini JCW
2010 123D Msport
2011 135i Coupe DCT
2007 Mini Cooper S
Return to “F87 M2”
