OBD mandatory for JB4?
rydale13
Post by rydale13 » Sat Jan 13, 2018 8:16 pm
Hi guys,
I'm toying the with the idea of purchasing a JB4 for my M135i and bolt info on the Bluetooth module also.
As I understand it, the Bluetooth module will allow me to switch maps via an app.
What I now want to understand is whether the hook up to the OBD port is necessary with the Bluetooth module?
I understand I won't be able to change maps using the dash, but will the JB4 ultimately still work?
Thanks in advance.
sootyvrs
Re: OBD mandatory for JB4?
Post by sootyvrs » Sat Jan 13, 2018 8:37 pm
If I recall you can only use map1 if you do not connect up the odb2 cable on the N55
They did make a firmware change for B58 JB4 where you can use the standard maps 1,2 & 3 if I recall but not sure if tgis was done for the F55 M135 JB4
2018 F87 BMW M2 DCT
2017 F21 BMW M140i Auto
2015 F56 Mini Cooper S Man
2013 F20 BMW M135i Auto
2010 R56 Mini Cooper D Man
2007 E87 BMW 130i Man
Blind Pugh
Post by Blind Pugh » Sun Jan 14, 2018 8:04 am
Correct - maps 0 & 1 only for n55 with no canbus hooked up via OBD port. No data logging capability either nor monitoring via JB4 app meaning extra spend on BT JB4 connect is a waste of money. You can change maps wo using app
AW M2 DCT
jason@bwchiptune
Post by jason@bwchiptune » Sun Jan 14, 2018 11:27 am
If you don't connect to the obd can wires you can have problems with the jb4 not making power
I've seen a good few times
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road
BW autorepairs
Over 30 year repairing BMWs
New and fully refurbished BMW,Alpina Ecus and Cas units
BMW Keys made and cut same day
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used)
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars
DPF repairs fixed without the need of removal of its guts or replacement
40% of my work is repairing the problems that are caused by other tuners Remaps
0208 561 1818
07831 103030
Hayes
UB3 1BB
Click here for: BMW Remaps
Click here for: BMW Repairs
DynoDynamics rolling road testing in london & newcastle
dealers across the uk
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
Bmw_ire_2012
Post by Bmw_ire_2012 » Mon Jan 15, 2018 2:54 pm
Hi guys,
Thanks in advance.
I think you can now get a OBD flash tune done, this might be the better option for you.
M240i Loaded With Options & M Performance Parts. Jb4 / Led M Performance Wheel / Bcs Full System - Sports Cat / BMW M Performance 624 Wheels :evil:
