Rear Windscreen Heater not working
parin
Post by parin » Sun Nov 06, 2011 11:05 am
My rear windscreen heater has stopped working on my 2007 118d (E81). The wing mirrors heat up when the rear heater button is pressed.
Anyone had a similar issue? Or know what to look for?
I've removed the trim and the connector seems ok.
Deezer-D
Re: Rear Windscreen Heater not working
Post by Deezer-D » Sun Nov 06, 2011 11:21 am
Check the fuse?
parin
Post by parin » Sun Nov 06, 2011 12:55 pm
Fuses are fine.
russell hayward
Post by russell hayward » Mon Jan 23, 2012 10:38 am
Mine has done the same, was this fixed ?
weasley
Post by weasley » Mon Jan 23, 2012 11:07 am
Just an observation, but the mirrors are not linked to the rear heated screen, so this is a bit of a red herring in fault diagnosis.
I'd be looking at the connectors on the rear screen and looking for any breaks in the fine wiring on the screen. If nothing obvious, and the fuse is OK, then it might be the switch. If not, then unless you fancy tracing the wiring it'll need diagnosis by a specialist.
130i M-Sport
2007 (56)
Le Mans Blue
Gone, but never forgotten.
Return to “BMW Problems”
